evil alias rule strikes again
Kate Feng
feng1 at bnl.gov
Thu Nov 8 21:22:52 UTC 2007
Till Straumann wrote:
> Today, I was again hit by the alias rule when a driver
> stopped working.
I really do not see this as an evil b/c I have seen the worst. :-)
I think most people are using -fno-strict-aliasing except
it is forgotten to be updated in the release,
where all the makefile are for the BSP (e.g. make/custom).
The make/custom is not where each BSP is. Thus it is easy
to be ignored. However, the compiling warning message
without the -fno-strict-aliasing option could be so ugly that
one could simply update the makefile for the system
without thinking.
I had a look at the mvme5500.cfg and found out that
I have been using the -fno-strict-aliasing option. However,
it was not updated in the CVS. I will submit a PR
for the mvme5500.cfg. However, this does not imply
that -fno-strict-aliasing will solve all alias problems.
Kate
> I have a driver which uses
> #include <libcpu/byteorder.h>
> /* Driver defines helper inline function for swapping to LE */
> static inline uint32_t
> swp32(uint32_t v)
> unsigned rval;
> st_le32(&rval,v);
> return rval;
> and the driver then does things, simplified:
> void test(uint32_t *buf)
> buf[0] = swp32(0xdeadbeef);
> buf[1] = swp32(0xcafecafe);
> However, recently Ralf changed byteorder.h so that st_le32 is no
> longer
> static inline void st_le32( volatile unsigned *a, unsigned v);
> but it is now
> static inline void st_le32( volatile uint32_t *a, unsigned v);
> which introduces a violation of the alias rule into 'swp32'.
> The compiler now may assume that st_le32 does not modify
> 'rval' above because according to the alias rule
> the pointer argument to st_le32 must not alias 'rval'
> since rval is unsigned and the pointer
> is a pointer to uint32_t which are incompatible.
> Indeed, gcc-4.2.2 does use that assumption (it warns about
> incompatible pointer types but gives no type-punnning warning).
> Just another example for how a small change (in this case:
> to the byteorder.h header) can have big effects that are
> hard to track down.
> How many more of these incidents do we need to convince
> you to use -fno-strict-aliasing (linux uses it) ?
> More detailed description attached...
> -- Till
>#include <stdint.h>
>/* This is from <libcpu/byteorder.h>; type was changed
> * recently changed (vers. 1.6 -> 1.7)
> * from
> * volatile unsigned *
> * to
> * volatile uint32_t *
>static inline void st_le32(volatile uint32_t *a, unsigned v)
> __asm__ __volatile__ ("stwbrx %1,0,%2" : "=m" (*a) : "r" (v), "r" (a));
>/* Some Driver defines inline function for swapping to LE */
>swp32(uint32_t v)
>unsigned rval __attribute__((may_alias));
>/* Change of types in byteorder.h introduces
> * violation of alias rule here; compiler assumes
> * unsigned cannot alias uint32_t
> st_le32((volatile uint32_t*)&rval,v);
> return rval;
> buf[0] = swp32(0);
> /* Gcc assumes pointer passed to st_le32() cannot't alias
> * 'rval' above and therefore it stores a cached value
> * in buf[1].
> buf[1] = swp32(1);
> 00000000 <test>:
> 0: 94 21 ff e8 stwu r1,-24(r1)
> 4: 38 00 00 00 li r0,0
> 8: 39 21 00 08 addi r9,r1,8
> c: 7c 00 4d 2c stwbrx r0,0,r9
> 10: 81 61 00 08 lwz r11,8(r1)
> 14: 38 00 00 01 li r0,1
> 18: 91 63 00 00 stw r11,0(r3)
> 1c: 7c 00 4d 2c stwbrx r0,0,r9
> 20: 38 21 00 18 addi r1,r1,24
> 24: 91 63 00 04 stw r11,4(r3)
> 28: 4e 80 00 20 blr
> which corresponds to
> rval = bytereverse(0)
> buf[0] = rval;
> buf[1] = rval;
> rval = bytereverse(1)
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.com
>http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20071108/83f42e01/attachment.html>
