No acceptable C compiler found
Jalpan Dholakia
jalpan.dholakia at nxp.com
Tue Nov 13 15:17:41 UTC 2007
Hi Ralf,
I have set <arm tool install point>/bin in the $ PATH which include
arm-rtems4.7-gcc.exe , autoconf etc. files. I am not doing any thing
with the cc1.
I am also giving prefix in configure command like - -
prefix=/h/RTEMS/msys/arm/bin . As I said prefix has no effect. If it has
then why it is giving error for $PATH like "No acceptable C compiler found
in $PATH" ?
Regards.
On Tue, 2007-11-13 at 07:59 -0600, Joel Sherrill wrote:
> + MinGW doesn't run on Vista correctly. The native compiler
> dies compiling hello world with a message like
> "cc1 not found".
cc1 not found indicates a toolchain relocation error.
In general, GCCs based toolchains are not relocatible and must be
installed into the prefix they have been configured for.
> We searched online and others have
> run into this but the only solution I saw was to put the
> directory with cc1 in your PATH but that results in the
> RTEMS cross compiler finding the native cc1 not the
> cross one.
Right. As you might recall, cross tools are named <host>-<tool>.
You MUST not put the directory containing cc1 into $PATH.
Ralf
URL: <http://lists.rtems.org/pipermail/users/attachments/20071113/0b0b2787/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20071113/0b0b2787/attachment.gif>
