External RAM filesystem
Aitor.Viana.Sanchez at esa.int
Wed Nov 14 11:02:34 UTC 2007
Hi Thomas,
I managed to configure the RAMDISK, and also accessing it but i got couple
of questions.
- I didn't use the msdos_initialize function at all and I don't
know what this function does exactly and why it is needed.
- I had also to initialize the rtems_bdbuf_configuration structure
and the rtems_bdbuf_configuration_size variable, but i don't know what is
this structure/variable is for.
- I can access to the RAMDISK by means of fopen("/dev/ramdisk0")
for instance. But this allows me to write/read in the RAMDISK area using
the file API. But apparently does not allow me to create files in the
RAMDISK area (which is my intention). Lets say, I want to allocate a
RAMDISK area, mount it, and then access it like a filesystem.
Here is my configuration file:
#ifndef RTEMSCONFIG_H_
#define RTEMSCONFIG_H_
/* configuration information */
rtems_task Init( rtems_task_argument argument);
#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS 10
#define CONFIGURE_MAXIMUM_SEMAPHORES 10
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
rtems_bdbuf_config rtems_bdbuf_configuration[] = {
{ 512, 20, (void *) 0 }
int rtems_bdbuf_configuration_size = 1;
rtems_ramdisk_config rtems_ramdisk_configuration[] = {
512, 20, (void *) 0
int rtems_ramdisk_configuration_size = 1;
#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
rtems_driver_address_table Device_drivers[] = {
CONSOLE_DRIVER_TABLE_ENTRY,
CLOCK_DRIVER_TABLE_ENTRY,
RAMDISK_DRIVER_TABLE_ENTRY
#define CONFIGURE_NUMBER_OF_DRIVERS \
((sizeof(Device_drivers) / sizeof(rtems_driver_address_table)))
#define CONFIGURE_MAXIMUM_DRIVERS 10
#define CONFIGURE_INIT
#include <confdefs.h>
#endif /*RTEMSCONFIG_H_*/
Cheers,
Aitor
Aitor Viana Sánchez
ESA - European Space Technology Centre (ESTEC)
TEC-EDD - Computer and Data Systems Section
ESA/ESTEC P.O. Box 299 / 2200AG Noordwijk ZH, The Netherlands
Tel (+31) 71 565 6727
Email: aitor.viana.sanchez at esa.int
Thomas Doerfler <Thomas.Doerfler at embedded-brains.de>
11/13/2007 05:47 PM
To
cc
rtems-users at rtems.org
Subject
Re: External RAM filesystem
Hi,
yes, it should be possible. There still exists a ram disk driver, which
performs this function, see:
cpukit/libblock/src/ramdisk.c
We used it for our very first tests of the FATFS. If I recall correctly,
these are the steps to work with it:
- define a rtems_ramdisk_config data structure (e.g. in the init module)
with the fixed name "rtems_ramdisk_configuration".
- you can/must define the block size, the number of blocks and location
in this structure
- If you add the RAMDISK_DRIVER_TABLE_ENTRY to your device driver table,
it will initialize automatically when your system comes up
- Or, you can initialize the ramdisk with "ramdisk_initialize".
- Next, you must format the ramdisk (use msdos_format function in
cpukit/libfs/src/dosfs/msdos_format.c).
- Then you can mount the ramdisk as a (unpartitioned) volume with
msdos_initialze().
I hope I am rather acurate on these steps.
It would be nice if you could give us feedback, when things work.
And it would be even nicer, if you could write a wiki entry on this
under www.rtems.com/wiki
wkr,
Thomas.
Aitor.Viana.Sanchez at esa.int schrieb:
> Hi all,
> is it possible to configure RTEMS somehow to access and external RAM
> memory address where a FAT32 (for instance) file system is placed? Is it
> possible to configure the address and size?
> Thanks in advance.
> Aitor
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
Tel. : +49-89-18 90 80 79-2
Fax : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
URL: <http://lists.rtems.org/pipermail/users/attachments/20071114/d788a883/attachment.html>
