External RAM filesystem
Aitor.Viana.Sanchez at esa.int
Fri Nov 16 17:04:44 UTC 2007
Hi,
OK the problem eventually was only half mine ;). I'll try to explain.
The LEON2 board i got has 64MB of SDRAM memory placed in the address
0x60000000, and I want to locate the ramdisk filesystem within that area.
The configuration is:
rtems_bdbuf_config rtems_bdbuf_configuration[] = {
{ 512, numberOfBlocks, (unsigned char *) _SDRAM_FS_ADDR }
int rtems_bdbuf_configuration_size = 1;
rtems_ramdisk_config rtems_ramdisk_configuration[] = {
{512, numberOfBlocks, (void *) _SDRAM_FS_ADDR}
where _SDRAM_FS_ADDR is 0x60000000 and numberOfBlocks is the size of the
filesystem i want to placed divided by 512 (which is the block size),
actually:
#define _FILESYSTEM_SIZE (0x1000000) //
16MB
static unsigned int numberOfBlocks = (_FILESYSTEM_SIZE / 512);
The problem is that, with this numberOfBlocks value, RTEMS is not able to
mount the filesystem, raising an error. The error shows up when
msdos_format() is called, returning "not such file or directory". On the
contrary, if numberOfBlocks = 40 (for instance) everything goes well.
Is there any limitation within RTEMS w.r.t. the size of the filesystem?
thanks in advanced.
//avs
Aitor Viana Sánchez
ESA - European Space Technology Centre (ESTEC)
TEC-EDD - Computer and Data Systems Section
ESA/ESTEC P.O. Box 299 / 2200AG Noordwijk ZH, The Netherlands
Tel (+31) 71 565 6727
Email: aitor.viana.sanchez at esa.int
Thomas Doerfler <Thomas.Doerfler at embedded-brains.de>
Sent by: rtems-users-bounces at rtems.org
11/15/2007 09:54 PM
To
cc
rtems-users at rtems.org
Subject
Re: External RAM filesystem
Hi,
Aitor.Viana.Sanchez at esa.int schrieb:
> Hi,
> I got everything ready to send an example and to include a wiki entry
> but fist...the example is only working in rtems-4.7.99.2-1.0.3. I also
> tried with RTEMS 4.6.5 but looks like some functions are not implemented
> in this version. This is the compilation output.
ys you are right, I implemented the msdos_format function somewhere
after 4.6.5, so you might have missed it in that version.
See:
http://www.rtems.com/cgi-bin/cvsweb.cgi/rtems/cpukit/libfs/src/dosfs/msdos_format.c
The module should be back-portable if required, but there might be some
other unresolved references then.
Are you currently stuck to 4.6.5 in your work? Which architecture are
you working on?
wkr,
Thomas.
Embedded Brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax: +49-89-18908079-9
rtems-users mailing list
rtems-users at rtems.com
http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20071116/f6568258/attachment.html>
