autoconf on CVS source
Ralf Corsepius ralf.corsepius at rtems.org
Sun Nov 18 18:21:27 UTC 2007
On Sun, 2007-11-18 at 11:55 -0500, Hoan Hoang wrote:
> Hi,
>    I got rtems from CVS.  It doesn't contains the configure script so I
> ran autoconf and got an error.
> configure.ac:19: error: possibly undefined macro: AM_INIT_AUTOMAKE
> what should I do ? I can't autoconf so can't configure, can't build
Install autoconf and automake.
Then
cd <root-of your cvs checkout>
./bootstrap
Which versions of automake/autoconf to use and how to install them
depends on the OS you are using.
The versions being shipped by modern Linuxes probably will suffice
(CVS-HEAD needs autoconf >= 2.61, automake-1.10).
Users of older rpm-based Linuxes can use the rpms to be found on
ftp.rtems.org (for CVS-HEAD you will want the rtems-4.9-* packages).
Users of other OS will have check the versions their vendors might be
shipping or will have have to resort to install from sources (to be
found on any gnu-mirror)
Ralf
