No acceptable cc found in $PATH
Paul Whitfield paulw at omnitronics.com.au
Thu Nov 22 23:30:39 UTC 2007
Jalpan Dholakia wrote:
> Hello,
> Under development environment Fedora Linux
> after bootstrap I ran configure command and also added - -
> prefix=/opt/rtems4.7 once configured I have done
> make all install
> and I stuck with the error
You should re-try the configure with the target option as
--target=arm-rtems4.7
Best of luck
Paul
