Questions on RTEMS GDB stub over a serial line
Till Straumann strauman at slac.stanford.edu
Tue Nov 27 16:45:51 UTC 2007
Ian Jiang wrote:
> Hi rtems-usersall!
> I am establishing a remote debug enviroment of RTEMS in a VMware workstation. I am using Till Straumann's GDB Agent for RTEMS. I referred http://www.slac.stanford.edu/~strauman/rtems/gdb/ but I am not clear enough about how to setup a session between the host and the target using a serial port.
> Questions
> 1) Where is the serial device?
> Some codes were added to list all file under /dev/ but only /dev/console was found.
You'd have to add 'TTY1_DRIVER_TABLE_ENTRY' to the driver table.
Since this driver is unkown to confdefs.h you would have to
#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
and add a device driver table, see e.g, cpukit/pppd/example/system.h
BTW: AFAIK, hello normally uses a minimal configuration w/o a
clock driver but the gdb stub probably won't work w/o a clock.
Thus, make sure you add CLOCK_DRIVER_TABLE_ENTRY to
the device driver table.
> 2) Is my test program correct?
> The source codes are attached at last.
I believe the tty driver creates file-system entries /dev/ttyS1 (and
/dev/ttyS2
if the second device is configured). Hence, you'd have to call
rtems_gdb_start(0, "/dev/ttyS1")
Also, you might want to insert a breakpoint - otherwise
your application executes to the end before you have a chance
to attach the debugger and interrupt the program.
Just call
rtems_gdb_breakpoint()
(anywhere after rtems_gdb_start())
> 3) Why no debugging symbols found in the hello.exe although flag -g was used?
Has been answered already; you want to use 'hello.nxe'.
HTH
-- Till
(PS: could you get the network driver working? I still have to look
at the binaries you sent -- just haven't found the time yet, sorry)
> ian at IanVM-1:~/src/examples-4.7.1/hello4gdb> /opt/gdb-6.5/i386-rtems-gdb
> GNU gdb 6.5
> Copyright (C) 2006 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and you are
> welcome to change it and/or distribute copies of it under certain conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB.  Type "show warranty" for details.
> This GDB was configured as "--host=i686-pc-linux-gnu --target=i386-ssrl-rtems".
> (gdb) file ./o-optimize/hello.exe
> Reading symbols from /home/ian/src/examples-4.7.1/hello4gdb/o-optimize/hello.exe...(no debugging symbols found)...done.
> More Information
> RTEMS Configuration
> My host is Suse-10.1 with RTEMS-4.7.1 that configured as
> ian at IanVM-1:~/rtems/b-rtems_debug> ../../src/rtems-4.7.1/configure --target=i386-rtems4.7 --quiet --enable-posix --enable-networking --enable-cxx --enable-rtemsbsp=pc386 --enable-rdbg --prefix=/home/ian/rtems/rtems_debug-4.7.1 CFLAGS=-fno-strict-aliasing
> GDB and the Stub
> I installed GDB 6.5 with patches of GDB stub for RTEMS 1.4(http://www.slac.stanford.edu/~strauman/rtems/gdb/RTEMS_gdb_stub_1_4.tgz) and the GDB stub for RTEMS without using Cexp or libbspext.
> I also installed libbspExt-1.3beta and "bsd_eth_drivers" from Till , because they were required while building my simple hello-world test.
> About the two Vitual Machines
> One is the host that has RTEMS developing tools, the other is the target where RTEMS hello-world runs. They are connected with a serial line (a virtual line provided by the VMware workstation).
> Output of hello.exe
> Initialized console on port CONSOLE
> List of dir /:
> name			inode	offset	reclen	type
> dev					2		0		268i
> List of dir /dev/:
> console				8		0		268i
> Task App Enter
> GDB daemon (Release $Name: RTEMS_gdb_stub_1_4 $): starting up
> *** HELLO WORLD TEST ***
> Hello World
> *** END OF HELLO WORLD TEST ***
> Task App Exit
> GDB daemon - opening tty: No such file or directory
> GDB daemon: shutting down
> Souce Codes of hello.exe
> ian at IanVM-1:~/src/examples-4.7.1/hello4gdb> cat test.c
>  *      Simple test program -- simplified version of sample test hello.
> #define TEST_INIT
> #include <tmacros.h>
> #include <bsp.h>
> #include <stdlib.h>
> #include <stdio.h>
> #include <sys/types.h>
> #include <fcntl.h>
> #include <dirent.h>
> #include <errno.h>
> #include <string.h>
> #include <rtems/rtems_bsdnet.h>
> #include <rtems-gdb-stub.h>
> #include <bsp/bspExt.h>
> #include "networkconfig.h"
> #define TASK_PRIORITY_APP 4
> void printdir(char *dir_name)
>         struct dirent *d;
>         DIR *dir;
>         if (dir_name == NULL) {
>                 printf("NULL dir name\n");
>                 return;
>         dir = opendir(dir_name);
>         if (dir == NULL) {
>                 printf("open dir %s failed:%s\n", dir_name, strerror(errno));
>                 return;
>         printf("List of dir %s:\n", dir_name);
>         printf( "%-20s %8s %8s %8s %4s\n",
>                  "name", "      inode", " offset", "reclen", " type" );
>         d = readdir(dir);
>         while (d) {
>                 printf( "%-20s %8d %8d %6di\n",
>                          d->d_name, (int)d->d_ino, (int)d->d_off, d->d_reclen);
>                 d = readdir(dir);
>         return;
> rtems_task
> app_task (rtems_task_argument ignored)
>         rtems_status_code ret;
>         printf("Task App Enter\n");
>         rtems_gdb_start(0, "/dev/ttyS0");
>         printf( "\n\n*** HELLO WORLD TEST ***\n" );
>         printf( "Hello World\n" );
>         printf( "*** END OF HELLO WORLD TEST ***\n" );
>         /* delete myself and exit */
>         printf("Task App Exit\n");
>         ret = rtems_task_delete(RTEMS_SELF);
>         directive_failed(ret, "Delete task App");
> rtems_task Init(
>         rtems_name app_name;
>         rtems_id app_id;
>         printdir("/");
>         printdir("/dev/");
>         /* create and start application task */
>         app_name = rtems_build_name('a', 'p', 'p', '0');
>         ret = rtems_task_create(app_name,
>                         TASK_PRIORITY_APP,
>                         RTEMS_MINIMUM_STACK_SIZE,
>                         RTEMS_DEFAULT_MODES,
>                         RTEMS_DEFAULT_ATTRIBUTES,
>                         &app_id);
>         directive_failed(ret, "Create task App");
>         ret = rtems_task_start(app_id, app_task, 0);
>         directive_failed(ret, "Start task App");
>         directive_failed(ret, "Delete task Init");
> /* configuration information */
> #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> #define CONFIGURE_MAXIMUM_TASKS 4
> #define CONFIGURE_EXECUTIVE_RAM_SIZE    (512*1024)
> #define CONFIGURE_INIT
> #include <rtems/confdefs.h>
> /* end of file */
> ian at IanVM-1:~/src/examples-4.7.1/hello4gdb> cat Makefile
> #  $Id: Makefile,v 1.4 1998/08/21 13:26:05 joel Exp $
> SAMPLE=hello
> PGM=${ARCH}/$(SAMPLE).exe
> MANAGERS=all
> # C source names, if any, go here -- minus the .c
> C_PIECES= test
> C_FILES=$(C_PIECES:%=%.c)
> C_O_FILES=$(C_PIECES:%=${ARCH}/%.o)
> H_FILES=
> DOCTYPES=
> DOCS=$(DOCTYPES:%=$(SAMPLE).%)
> SRCS=$(DOCS) $(C_FILES) $(CC_FILES) $(H_FILES) $(S_FILES)
> OBJS=$(C_O_FILES) $(CC_O_FILES) $(S_O_FILES)
> PRINT_SRCS=$(DOCS)
> include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
> include $(RTEMS_CUSTOM)
> include $(PROJECT_ROOT)/make/leaf.cfg
> # (OPTIONAL) Add local stuff here using +=
> DEFINES  +=
> CPPFLAGS +=
> CFLAGS_LD += -Wl,--defsym -Wl,HeapSize=0xC0000
> CFLAGS_OPTIMIZE_V   +=
> CFLAGS_DEBUG_V   += -v -qrtems_debug
> CFLAGS_LD += -g
> CFLAGS   += -fno-strict-aliasing -O
> CFLAGS   += -I${RTEMS_MAKEFILE_PATH}/include
> CFLAGS   += -I/home/ian/src/examples-4.7.1/test_includes
> CFLAGS   += -g
> CFLAGS   += -Wall
> #OP_SYS_LDFLAGS = -g
> LD_PATHS  += -L${RTEMS_MAKEFILE_PATH}/lib
> #LD_LIBS   += -lif_le -lbsdport -lbspExt
> LD_LIBS   += -lrtems-gdb-stub -lif_le -lbsdport -lbspExt
> #LD_LIBS   += -lrtems-gdb-stub
> LIBS   +=  -lrtemsall -lc
> # Add your list of files to delete here.  The config files
> #  already know how to delete some stuff, so you may want
> #  to just run 'make clean' first to see what gets missed.
> #  'make clobber' already includes 'make clean'
> CLEAN_ADDITIONS +=
> CLOBBER_ADDITIONS +=
> all:    ${ARCH} $(SRCS) $(PGM)
> ${PGM}: $(OBJS) $(LINK_FILES)
>         $(make-exe)
> # Install the program(s), appending _g or _p as appropriate.
> # for include files, just use $(INSTALL)
> install:  all
>         $(INSTALL_VARIANT) -m 555 ${PGM} ${PROJECT_RELEASE}/tests
> ian at IanVM-1:~/src/examples-4.7.1/hello4gdb> cat networkconfig.h
>  * Network configuration
>  * EDIT THIS FILE TO REFLECT YOUR NETWORK CONFIGURATION     *
>  * BEFORE RUNNING ANY RTEMS PROGRAMS WHICH USE THE NETWORK! *
>  *  $Id: networkconfig.h,v 1.8 2001/08/31 18:11:43 joel Exp $
> #ifndef _RTEMS_NETWORKCONFIG_H_
> #define _RTEMS_NETWORKCONFIG_H_
> //#define USE_QEMU
>  *  The following will normally be set by the BSP if it supports
>  *  a single network device driver.  In the event, it supports
>  *  multiple network device drivers, then the user's default
>  *  network device driver will have to be selected by a BSP
>  *  specific mechanism.
> #ifdef RTEMS_BSP_NETWORK_DRIVER_NAME
> #undef RTEMS_BSP_NETWORK_DRIVER_NAME
> #endif
> #ifdef USE_QEMU
> #define RTEMS_BSP_NETWORK_DRIVER_NAME BSP_NE2000_NETWORK_DRIVER_NAME
> #else
> #define RTEMS_BSP_NETWORK_DRIVER_NAME "le1"
> #endif
> #ifdef RTEMS_BSP_NETWORK_DRIVER_ATTACH
> #undef RTEMS_BSP_NETWORK_DRIVER_ATTACH
> #endif
> #ifdef USE_QEMU
> #define RTEMS_BSP_NETWORK_DRIVER_ATTACH BSP_NE2000_NETWORK_DRIVER_ATTACH
> #else
> #define RTEMS_BSP_NETWORK_DRIVER_ATTACH libbsdport_netdriver_attach
> #endif
> #include <rtems/pci.h>
> #include <rtems/irq.h>
> #ifndef USE_QEMU
> #include <bsp/libbsdport_api.h>
> extern driver_t libbsdport_le_pci_driver;
> driver_t *libbsdport_netdriver_table[] = {
>         &libbsdport_le_pci_driver,
>         /* other drivers here or upstream of 'le' if they support
>         * the same hardware but are preferred.
>         0
> #endif
> /* #define RTEMS_USE_BOOTP */
> #include <bsp.h>
>  * Define RTEMS_SET_ETHERNET_ADDRESS if you want to specify the
>  * Ethernet address here.  If RTEMS_SET_ETHERNET_ADDRESS is not
>  * defined the driver will choose an address.
> #ifndef USE_QEMU
> #define RTEMS_SET_ETHERNET_ADDRESS
> #endif
> #if (defined (RTEMS_SET_ETHERNET_ADDRESS))
> /* static char ethernet_address[6] = { 0x08, 0x00, 0x3e, 0x12, 0x28, 0xb1 }; */
> static char ethernet_address[6] = { 0x00, 0x80, 0x7F, 0x22, 0x61, 0x77 };
> #endif
> #ifdef RTEMS_USE_LOOPBACK
>  * Loopback interface
> extern void rtems_bsdnet_loopattach();
> static struct rtems_bsdnet_ifconfig loopback_config = {
>         "lo0",                          /* name */
>         rtems_bsdnet_loopattach,        /* attach function */
>         NULL,                           /* link to next interface */
>         "127.0.0.1",                    /* IP address */
>         "255.0.0.0",                    /* IP net mask */
> #endif
>  * Default network interface
> static struct rtems_bsdnet_ifconfig netdriver_config = {
>         RTEMS_BSP_NETWORK_DRIVER_NAME,          /* name */
>         RTEMS_BSP_NETWORK_DRIVER_ATTACH,        /* attach function */
>         &loopback_config,               /* link to next interface */
> #else
>         NULL,                           /* No more interfaces */
> #endif
> #if (defined (RTEMS_USE_BOOTP))
>         NULL,                           /* BOOTP supplies IP address */
>         NULL,                           /* BOOTP supplies IP net mask */
> #else
>         //"XXX.YYY.ZZZ.XYZ",            /* IP address */
> #ifdef USE_QEMU
>         "192.168.10.230",               /* IP address */
> #else
>         "192.168.1.230",                /* IP address */
> #endif
>         "255.255.255.0",                /* IP net mask */
> #endif /* !RTEMS_USE_BOOTP */
>         ethernet_address,               /* Ethernet hardware address */
> #else
>         NULL,                           /* Driver supplies hardware address */
> #endif
> #ifndef USE_QEMU
>         0                               /* Use default driver parameters */
> #else
>         0,                              /* Use default driver parameters */
>         0,
>         0,
>         0,
>         0x300,
>         9,
>         0
> #endif
> struct rtems_bsdnet_config rtems_bsdnet_config = {
>         &netdriver_config,
>         rtems_bsdnet_do_bootp,
> #else
>         NULL,
> #endif
>         0,                      /* Default network task priority */
>         0,                      /* Default mbuf capacity */
>         0,                      /* Default mbuf cluster capacity */
> #if (!defined (RTEMS_USE_BOOTP))
>         "IanVM-N0",             /* Host name */
>         "nodomain.com",         /* Domain name */
>         "192.168.1.254",        /* Gateway */
>         "192.168.1.241",        /* Log host */
>         {"192.168.1.106" },     /* Name server(s) */
>         {"192.168.1.241" },     /* NTP server(s) */
>          *  A real example -- DO NOT USE THIS YOURSELF!!!
> #if 0
>         "dy4",                  /* Host name */
>         "NOT_oarcorp.com",      /* Domain name */
>         "192.168.1.2",          /* Gateway */
>         "192.168.1.2",          /* Log host */
>         {"192.168.1.2" },       /* Name server(s) */
>         {"192.168.1.2" },       /* NTP server(s) */
> #endif
>  * For TFTP test application
> #define RTEMS_TFTP_TEST_HOST_NAME "BOOTP_HOST"
> #define RTEMS_TFTP_TEST_FILE_NAME "BOOTP_FILE"
> #else
> #define RTEMS_TFTP_TEST_HOST_NAME "XXX.YYY.ZZZ.XYZ"
> #define RTEMS_TFTP_TEST_FILE_NAME "tftptest"
> #endif
> #endif /* _RTEMS_NETWORKCONFIG_H_ */
> Ian Jiang
> ianjiang.cn at gmail.com
> 2007-11-27 20:09:23
> rtems-users mailing list
> rtems-users at rtems.com
