答复: CVS problem
ZhangZhiming
paopaoerzhang at msik.com.cn
Mon Nov 5 07:33:12 UTC 2007
cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -rrtems-4-8-branch
you can use this
I test it ok
_____
发件人: rtems-users-bounces+paopaoerzhang=msik.com.cn at rtems.org
[mailto:rtems-users-bounces+paopaoerzhang=msik.com.cn at rtems.org] 代表 鑫 赖
发送时间: 2007年11月5日 15:19
收件人: rtems-users at rtems.org
主题: CVS problem
i use "cvs -z 9 co -rrtems-4-8-branch rtems" to check out source code, but
it failed.Server didn't response.
_____
@yahoo.cn <https://member.cn.yahoo.com/cnreg/reginfo.html?id=89034> 新域
名、无限量,快来抢注!
*****CONFIDENTIAL INFORMATION*****
This email is intended only for the use of the person or entity to whom it is addressed and contains information that may be subject to and/or may be restricted from disclosure by contract or applicable law. If you are not the intended recipient of this email, be advised that any disclosure, copy, distribution or use of the contents of this message is strictly prohibited. If you are not the intended recipient of this email, please notify the sender that you have received this in error by replying to this message. Then, please delete it from your system. Thank you.
URL: <http://lists.rtems.org/pipermail/users/attachments/20071105/4448ff4d/attachment-0001.html>
