RTEMS autotools installation on mingw
Chris Johns
chrisj at rtems.org
Mon Nov 5 22:52:56 UTC 2007
Sven.BIEBAUT at be.thalesgroup.com wrote:
> I installed mingw, msys and msysDTK and proceeded as per the wiki page with
> the RTEMS tools installer(rtems4.8-tools-16.exe). As this development pc is
> not internet connected, I downloaded the packages first on a memory stick
> and installed them from there.
This should be ok.
> The RTEMS installer however complains about "Cannot open
> not-found/etc/fstab. MSYS mount point not added". Apparently this seems only
> to affect the autotools sub package. I tried setting the HOME environment
> variable, but this does not change alot.
This is the second report I have received about this problem. This was with a
machine that did not have MSYS etc installed before.
The installer was trying to update MSYS's /etc/fstab but it could not find MSYS.
> If I continue and disregard the message it will proceed with the actual
> compiler installation, but in the end complain that it couldn't find mingw.
Was it MinGW or MSYS it said it could not find ?
Where did you install MSYS and MinGW ?
> Is there something that I missed ? Do I need administrator rights or are
> there other environment variables necessary?
No you have not missed anything and you should not need administrator rights.
I can see an issue in the installer regarding the order it does the MSYS
detect and MSYS fstab update which I will fix.
I would like to know why the MSYS detect failed.
Regards
