DES encryption library
Samuel Bitton
S.Bitton at sstl.co.uk
Fri Nov 9 08:15:00 UTC 2007
Solved it.
This code is part of the networking code so I just had to enable network
in my build.
In my RTEMS version (a beta version with date stamp 12 Oct 2001), this
DES code is located in
c/src/librpc/.
Sam
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: 08 November 2007 17:08
To: Samuel Bitton
Cc: RTEMS Users Mailing List
Subject: Re: DES encryption library
Samuel Bitton wrote:
> Hi
> I want to use some of the DES encryption code located in the librtc.
Is this code in RTEMS? I know that there is some
DES code in the telnetd directory on the head.
> I can't find how to enable this library. Looked into the documentation
> and several README files in the code but no luck.
> Could someone enlighten me please?
Where is this again?
> Thanks.
> Sam
> rtems-users mailing list
> rtems-users at rtems.com
