External RAM filesystem
Aitor.Viana.Sanchez at esa.int
Wed Nov 14 16:09:06 UTC 2007
Based on the example i made (see bellow) i got questions.
Basically this example allows to read/write information in the RAMDISK
area (which is an array in the example) by means of the filesystem API but
does not allow to create files because the open/f_open routine shall open
the "/dev/ramdisk0" device.
Is it possible to "mount" somehow the /dev/ramdisk0 and then, using the
open/f_open, etc. calls to create file inside this RAMDISK?
Cheers,
Sitor
Here is the example I made.
rtems-config.h file --------------->
#ifndef RTEMSCONFIG_H_
#define RTEMSCONFIG_H_
/* configuration information */
rtems_task Init( rtems_task_argument argument);
extern char ramdisk[];
#define CONFIGURE_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS 10
#define CONFIGURE_MAXIMUM_SEMAPHORES 10
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
rtems_bdbuf_config rtems_bdbuf_configuration[] = {
{ 512, 40, (void *) ramdisk }
int rtems_bdbuf_configuration_size = 1;
rtems_ramdisk_config rtems_ramdisk_configuration[] = {
// The sparc-rtems-gcc version 4 changes the location of the confdefs.h
file.
#if (__GNUC__ > 3)
size_t rtems_ramdisk_configuration_size = 1;
rtems_task_priority swapout_task_priority = 100;
#else
int rtems_ramdisk_configuration_size = 1;
#endif
#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
rtems_driver_address_table Device_drivers[] = {
CONSOLE_DRIVER_TABLE_ENTRY,
CLOCK_DRIVER_TABLE_ENTRY,
RAMDISK_DRIVER_TABLE_ENTRY
#define CONFIGURE_NUMBER_OF_DRIVERS \
((sizeof(Device_drivers) / sizeof(rtems_driver_address_table)))
#define CONFIGURE_MAXIMUM_DRIVERS 10
#define CONFIGURE_INIT
file.
#if (__GNUC__ > 3)
#include <rtems/confdefs.h>
#else
#include <confdefs.h>
#endif
#endif /*RTEMSCONFIG_H_*/
test.c ----------------->
* Simple test program -- simplified version of sample test hello.
#include <bsp.h>
#include <assert.h>
#include <rtems/ramdisk.h>
#include <rtems/bdbuf.h>
char ramdisk[30*1024];
#include "rtems-config.h"
rtems_task Init(
rtems_task_argument ignored
FILE *fp;
unsigned char buffer[512];
unsigned char aux[512];
int i;
size_t bw;
// Open the RAMDISKK
fp = fopen( "/dev/ramdisk0", "r+" );
assert( fp );
for ( i=0 ; i< 512 ; i++ )
buffer[i] = (unsigned char) (i + 1);
for (i=0; i < 30 ; i++ )
bw = fwrite( buffer, 512, 1, fp );
assert(bw);
assert(fseek(fp, 0, SEEK_SET) == 0);
for (i=0; i < 20 ; i++ )
memset( aux, 0, 512 );
bw = fread( aux, 512, 1, fp );
assert( bw == 1 );
printf("%d ", i);
assert( !memcmp( buffer, aux, 512 ) );
assert( !memcmp( (ramdisk + (i*512)), aux, 512 ) );
exit( 0 );
/* end of file */
Aitor Viana Sánchez
ESA - European Space Technology Centre (ESTEC)
TEC-EDD - Computer and Data Systems Section
ESA/ESTEC P.O. Box 299 / 2200AG Noordwijk ZH, The Netherlands
Tel (+31) 71 565 6727
Email: aitor.viana.sanchez at esa.int
Joel Sherrill <joel.sherrill at oarcorp.com> wrote on 11/14/2007 03:15:07 PM:
> I don't remember if there is an example in the source
> tree anywhere of doing this. If you can put together
> something, it would be appreciated. Just declared
> some large byte array and use it as the RAM for the
> purposes of an example.
> --joel
> Aitor.Viana.Sanchez at esa.int wrote:
> > Hi Thomas,
> > I managed to configure the RAMDISK, and also accessing it but i got
> > couple of questions.
> > - I didn't use the msdos_initialize function at all and I
> > don't know what this function does exactly and why it is needed.
> > - I had also to initialize the rtems_bdbuf_configuration
> > structure and the rtems_bdbuf_configuration_size variable, but i don't
> > know what is this structure/variable is for.
> > - I can access to the RAMDISK by means of
> > fopen("/dev/ramdisk0") for instance. But this allows me to write/read
> > in the RAMDISK area using the file API. But apparently does not allow
> > me to create files in the RAMDISK area (which is my intention). Lets
> > say, I want to allocate a RAMDISK area, mount it, and then access it
> > like a filesystem.
> > Here is my configuration file:
> > #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
> > { 512, 20, (void *) 0 }
> > 512, 20, (void *) 0
> > Cheers,
> > Aitor
> > Aitor Viana Sánchez
> > *Thomas Doerfler <Thomas.Doerfler at embedded-brains.de>*
> > 11/13/2007 05:47 PM
> > To
> > cc
> > rtems-users at rtems.org
> > Subject
> > Re: External RAM filesystem
> > Hi,
> > yes, it should be possible. There still exists a ram disk driver,
which
> > performs this function, see:
> > cpukit/libblock/src/ramdisk.c
> > We used it for our very first tests of the FATFS. If I recall
correctly,
> > these are the steps to work with it:
> > - define a rtems_ramdisk_config data structure (e.g. in the init
module)
> > with the fixed name "rtems_ramdisk_configuration".
> > - you can/must define the block size, the number of blocks and
location
> > in this structure
> > - If you add the RAMDISK_DRIVER_TABLE_ENTRY to your device driver
table,
> > it will initialize automatically when your system comes up
> > - Or, you can initialize the ramdisk with "ramdisk_initialize".
> > - Next, you must format the ramdisk (use msdos_format function in
> > cpukit/libfs/src/dosfs/msdos_format.c).
> > - Then you can mount the ramdisk as a (unpartitioned) volume with
> > msdos_initialze().
> > I hope I am rather acurate on these steps.
> > It would be nice if you could give us feedback, when things work.
> > And it would be even nicer, if you could write a wiki entry on this
> > under www.rtems.com/wiki
> > wkr,
> > Thomas.
> > Aitor.Viana.Sanchez at esa.int schrieb:
> > > Hi all,
> > > is it possible to configure RTEMS somehow to access and external RAM
> > > memory address where a FAT32 (for instance) file system is placed?
Is it
> > > possible to configure the address and size?
> > > Thanks in advance.
> > > Aitor
> > > _______________________________________________
> > > rtems-users mailing list
> > > rtems-users at rtems.com
> > > http://rtems.rtems.org/mailman/listinfo/rtems-users
> > embedded brains GmbH
> > Thomas Doerfler Obere Lagerstr. 30
> > D-82178 Puchheim Germany
> > Tel. : +49-89-18 90 80 79-2
> > Fax : +49-89-18 90 80 79-9
> > email: Thomas.Doerfler at embedded-brains.de
> > PGP public key available on request
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20071114/6fda82c5/attachment-0001.html>
