External RAM filesystem
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Thu Nov 15 20:54:01 UTC 2007
Hi,
Aitor.Viana.Sanchez at esa.int schrieb:
> Hi,
> I got everything ready to send an example and to include a wiki entry
> but fist...the example is only working in rtems-4.7.99.2-1.0.3. I also
> tried with RTEMS 4.6.5 but looks like some functions are not implemented
> in this version. This is the compilation output.
ys you are right, I implemented the msdos_format function somewhere
after 4.6.5, so you might have missed it in that version.
See:
http://www.rtems.com/cgi-bin/cvsweb.cgi/rtems/cpukit/libfs/src/dosfs/msdos_format.c
The module should be back-portable if required, but there might be some
other unresolved references then.
Are you currently stuck to 4.6.5 in your work? Which architecture are
you working on?
wkr,
Thomas.
Embedded Brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
