Activate bsp_console_port_console on bsp_uart_com1
Arquer Stephane stephane.arquer at c-s.cnes.fr
Thu Nov 22 07:48:16 UTC 2007
Hello,
It's working fine for me too.
I configured
#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
rtems_driver_address_table Device_drivers[5] = {
	CONSOLE_DRIVER_TABLE_ENTRY,
	TTY1_DRIVER_TABLE_ENTRY,
	TTY2_DRIVER_TABLE_ENTRY,
	CLOCK_DRIVER_TABLE_ENTRY,
	{NULL, NULL, NULL, NULL, NULL, NULL}
TTY1_DRIVER_TABLE_ENTRY is the problem cause, it can't be configured both in the device drivers table an activated derectly in the console.c by the configure.
Thanks for the help.
sa
> -----Message d'origine-----
> De : Chris Johns [mailto:chrisj at rtems.org]
> Envoyé : mercredi 21 novembre 2007 06:45
> À : Arquer Stephane
> Cc : rtems-users at rtems.org
> Objet : Re: RE : Activate bsp_console_port_console on bsp_uart_com1
> Arquer Stephane wrote:
> > Thanks for the answer.
> > However, I've build another BSP using the following command
> line, the
> > console is initialized and I've the "TTYS1: port selected
> as console" message on the serial port, but no more messages
> and the target is frozen. Are there things else to configure ?
> Not for me. I can use this setting with qemu.
> Regards
> Chris
