getifaddrs support for rtems?
Thu Oct 4 18:34:44 UTC 2007
Ralf Corsepius wrote:
>>> On Fri, 2007-09-14 at 17:18 +0100, Keith Robertson wrote:
>>>>>> Hi.
>>>>>> http://www.rtems.com/ml/rtems-users/2006/december/thrd1.html#00142
>>>>>> indicates this has been asked before, and there appears to be some
>>>>>> sort of a (AFAIK somewhat involved) work around using the SIOCGIFADDR
>>>>>> ioctl.
>>>>>> However, most unixes these days seem to have this function and a few
>>>>>> related ones (getifaddrs freeifaddrs if_nametoindex if_indextoname
>>>>>> if_nameindex if_freenameindex).
>>>>>> On linux, these appear to be provided by glibc.  As newlib only
>>>>>> provides the core libc routines, it understandably doesn't appear to
>>>>>> provide these.  To improve the clean portability of other applications
>>>>>> to rtems, I'd like to find a way to implement these.   Where would
>>>>>> rtems typically obtain such helper routines?  Write them ourselves?
>>>>>> From somewhere in the *Bsd sources?  Elsewhere?
>>>>> The BSD sources are always the best starting point.   From there,
>>>>> all I can say is use the opengroup  description and write it yourself.
>>>> Stupid question: the freebsd man pages have entries for getifaddrs and
>>>> similar, however, I can't find it mentioned anywhere on lxr for freebsd
>>>> at: http://fxr.watson.org  For linux, this makes sense, as it's provided
>>>> by glibc, however, who would provide this for freebsd?
>>> Their libc - They all are there.
>>> Check out the freebsd source tree from their CVS and you'll find them.
>> Good news.  I've been able to add getifaddrs, if_nameindex, if_indextoname.
>> The original sources were taken from the freebsd tree and I only needed
>> to make very minor modifications (commented out a few freebsd related
>> header files).
> As this patch is pretty straight forward, I went ahead and checked in a
> slightly modified version into rtems-4-8-branch and CVS-HEAD.
Thanks.
Keith when you get a demo program for them, post it and we will
merge it
--joel
> Thanks,
> 	Ralf
> rtems-users mailing list
> rtems-users at rtems.com
