MCF5329EVB BSP
Fri Oct 5 19:54:24 UTC 2007
Till Straumann wrote:
> Just a reminder that the filesystem framework currently is not
> thread-safe!
Your outstanding patches are in the queue for 4.9.
--joel
> T.
> Joel Sherrill wrote:
>> Kirspel, Kevin wrote:
>>> I have almost completed a port to RTEMS of the MCF5329EVB evaluation
>>> board from Freescale. With this BSP I had to port the YAFFS2 file
>>> system to RTEMS. I would like to submit the BSP and YAFFS2 port to
>>> RTEMS. The YAFFS2 license is GPL. I don’t know if that is OK with
>>> RTEMS. I would like to do some robustness testing on the YAFFS2
>>> port. Does RTEMS have a test plan/procedure to validate new file
>>> systems?
>> Congratulations on the BSP and port. Is the license OK on the BSP?
>> Other email
>> deals with the YAFFS2 license issue.
>> There are POSIX tests which exercise files through the C library IO
>> calls and
>> should exercise all the functionality available through "normal"
>> APIs. You
>> would just have to arrange to have that mounted and the paths point
>> to it.
>> --joel
>>> Kevin Kirspel
>>> Opti Medical Systems
>>> Electrical Engineer
>>> 235 Hembree Park Drive
>>> Roswell GA 30076
>>> (ph) 770-510-4444 x4568
>>> (fax) 770-510-4445
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
