NFS
Kirspel, Kevin
kevin.kirspel at optimedical.com
Wed Oct 10 12:35:25 UTC 2007
I am trying to get an NFS client running on my system. I have looked at the
Wiki and README files within the source code but I am still a little
confused on what I need to do. From what I have gathered, the NFS needs the
"librpc.a" and "libxdr.a" libraries in order to function. In my rtems build
directory, I see that the librpc.a and libxdr.a libraries are created, but
when I do a "make install" the libraries are not copied to the install
directory. My first question is:
What do I have to do to the makefiles in order to get the librpc.a and
libxdr.a libraries installed?
I found some references in the README files to initialize the RPC by calling
rtems_rpc_task_init() function. There is also some reference to the
rtems_rpc_start_portmapper(). I am not sure what calls I need to make. My
second question is:
What is the procedure to start the NFS client? What rtems calls are needed?
If there are other things needed in order to get NFS working please let me
know.
Kevin Kirspel
Opti Medical Systems
Electrical Engineer
235 Hembree Park Drive
Roswell GA 30076
(ph) 770-510-4444 x4568
(fax) 770-510-4445
URL: <http://lists.rtems.org/pipermail/users/attachments/20071010/2c0023ae/attachment.html>
