Data type problem
Stéphane ARQUER
stephane.arquer at c-s.fr
Mon Oct 15 15:29:38 UTC 2007
When I compile the tsp files with my rtems application, there are error
messages like
../pc386/lib/include/netinet/in.h:65: error: expected
specifier-qualifier-list before 'u_long' And it's the same with
rpc/xdr.h with 'u_int', /rpc/clnt.h rpc.h ...
I think there is something wrong in my variables configuration in init.c
file or in my Makefile ?
The file error_out.txt show the messages.
sa
Le 15/10/2007, "Joel Sherrill" <joel.sherrill at oarcorp.com> a écrit:
>Stéphane ARQUER wrote:
>> Hello,
>> I'm working with Rtems v4.7.1 and the BSP pc386 and I want to use TSP
>> (Transport Sample Protocol (http://savannah.nongnu.org/projects/tsp/))
>> under Rtems. During the compilation there are several types like
>> uint32_t u_int, u_long which are not defined correctly. I think I have
>> to define some variables to allow compatibility with rpc, tcp ip ...
>The uint32_t should be defined correctly in stdint.h.
>Checking sys/types.h, I see this:
>./sys/types.h:typedef unsigned long u_long;
>What do you think is wrong?
>--joel
>> Thanks in advance for your help.
>> Regards.
>> SA
>> Stéphane ARQUER
>> CSSI - Division Aéronautique, Logiciels Embarqués
>> email: stephane.arquer at c-s.fr
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
Stéphane ARQUER
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20071015/2f449c13/attachment.bin>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20071015/2f449c13/attachment.txt>
