http network example
Thu Oct 18 15:35:13 UTC 2007
Arquer Stephane wrote:
> I'm using the 4.7 branch.
> Netdemo, netlink doesn't work to.
Then something is still wrong. It could be with the network
configuration in the networkconfig.h file.    Make sure the
settings for the IP address are OK.  With netdemo, you
can check the statistics and see if you are even getting interrupts.
--joel
>> -----Message d'origine-----
>> De : rtems-users-bounces+stephane.arquer=c-s.fr at rtems.org
>> [mailto:rtems-users-bounces+stephane.arquer=c-s.fr at rtems.org]
>> De la part de Joel Sherrill
>> Envoyé : jeudi 18 octobre 2007 15:02
>> À : Arquer Stephane
>> Cc : rtems-users at rtems.org
>> Objet : Re: http network example
>>> Hello,
>>> I configured my 3c905 nic with elnk driver from th Rtems
>> version 4.6.6
>>> with the http example. It's working correctly. I installed
>> Rtems 4.7.1
>>> and the http execution is frozen after the
>>> message: "etherlink: unit elnk1 driver attached".
>>> My configure parameters are :
>>> #define TEST_INIT
>>> #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
>>> #define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
>>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS	20
>>> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>>> #define CONFIGURE_EXECUTIVE_RAM_SIZE	(512*1024)
>>> #define CONFIGURE_MAXIMUM_SEMAPHORES	20
>>> #define CONFIGURE_MAXIMUM_TASKS			20
>>> #define CONFIGURE_MAXIMUM_TIMERS		5
>>> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES	5
>>> #define CONFIGURE_MICROSECONDS_PER_TICK	10000
>>> #define CONFIGURE_INIT_TASK_STACK_SIZE	(10*1024)
>>> #define CONFIGURE_INIT_TASK_PRIORITY	120
>>> #define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
>>>                                            RTEMS_NO_TIMESLICE | \
>>>                                            RTEMS_NO_ASR | \
>> RTEMS_INTERRUPT_LEVEL(0))
>>> Is there something else to add for this version ?
>> If you are using the 4.8 branch or CVS head and didn't edit
>> the Makefile, then there should be messages as init.c starts
>> the ftpd and simple httpd.  Then it just waits for you to
>> browse to it.
>> I assume that netdemo worked at this point.  If it didn't,
>> then it could just be a network issue.
>> --joel
>> --joel
>>> Stephane.
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
