Patch for "strict order mutex"
Fri Oct 19 15:22:00 UTC 2007
Ray wrote:
>   Thanks for your work. But pls compress your patch file before send to the maillist.
>   And I believe that you did not make the right patch in the attachment. It is hard to merge a patch file of 81,000 lines. It is a better idea to make a diff base on a freeze version (e.g. version 4.7.1 or CVS snapshot 4.7.99.2) because CVS is a moving target. It has to keep in mind that the patch should only contain your changes.
Diffing this type of code against CVS isn't a big deal.  Usually it is
actually easier
for me to merge a patch against CVS than an older released version.
But this patch wasn't generated in a way to be easy to deal with.  It
appears
to be a diff -uNr of a modified old tarball versus a fresh CVS checkout.
Merge your change into the fresh CVS and then do this from the top:
cvs diff -uN
If you added a file, there are techniques to deal with that so cvs will
think
you added it locally.  But for now, just send those separate from the
main diff.
Always update your cvs tree before doing a diff for submission.
It really is easier for me if you make a diff against the RTEMS version you
will merge into.  Most of the time this is against the CVS head.  Make your
diff's to that and keep your local cvs up to date with "cvs up -Pd"
--joel
> Thanks & Best Regards!
> Ray
> 2007-10-19
> From: xi yang
> Date: 2007-10-19 02:15:49
> To:   RTEMS Users; Joel Sherrill
> CC:
> Sub:  Patch for "strict order mutex"
>> 1)What's strict order mutex ?
>>  In rtems,when a task release a priority_inheritance or
>>  priority ceiling semaphore,the kernel detect whether
>>  this task holds priority_inheritance or priority
>>  ceiling semaphore, if not, set the priority of task
>>  back to real priority of task.
>>  This method  is right, but in theory, we would like
>>  to reset the priority after releasing the mutex if
>>  releasing it in LIFO order.Do it like this can decrease
>>  the blocking time of a higher priority task .
>> 2)How to enable "strict order mutex " ?
>>  When configuring the rtems , add
>>  ENABLE_STRICT_ORDER_MUTEX=1
>>  to your configure parameter.
>> I add sp36 to test the function of "strict order mutex"
>> 3)About this test program
>> T0,T1,S0,S1
>> T0,priority 4
>> T1,priority 1
>> S0,priority inheritance
>>  S1,priority ceiling,priority ceiling 2
>> 1,T0 obtain S0 then obtain S1, priority of T0 should be improved to 2
>> 2,T0 try to release S0, but not in strict order, return error code
>> 3,T0 release S1,the priority of T0 back to 4
>> 4,T1 try to obtain S0
>> 5,T1 should be blocked and the priority of T0 should be improved to 1
>> 6,T0 release S0
>> 7,T1 obtain S0
>> 8,OVER.
>> I test it under bochs , this patch is for rtems that check form CVS as
>> cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co
>> -rrtems-4-8-branch  rtems
>> Regards.
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
