RTEMS Manager definition (timeline tool)
Manuel Coutinho
manuel.coutinho at edisoft.pt
Tue Oct 23 15:58:02 UTC 2007
Regarding the timeline tool implementation under a configure option or an
RTEMS Manager:
We are not forcing the implementation of the Timeline Tool through a
manager, but probably there is a misconception on our mind regarding the
manager definition. For us, RTEMS Manager is a RTEMS block that should be
the only entry point (API) for the running RTEMS application, is inside the
cpukit and which the RTEMS initializes (typically inside
rtems_initialize_early). Is this definition correct? With this definition,
we believe that Timeline tool should be implemented as an RTEMS manager.
URL: <http://lists.rtems.org/pipermail/users/attachments/20071023/3102ec84/attachment.html>
