MCF5329EVB BSP
Till Straumann strauman at slac.stanford.edu
Fri Oct 5 19:22:35 UTC 2007
Just a reminder that the filesystem framework currently is not thread-safe!
T.
Joel Sherrill wrote:
> Kirspel, Kevin wrote:
>> I have almost completed a port to RTEMS of the MCF5329EVB evaluation
>> board from Freescale. With this BSP I had to port the YAFFS2 file
>> system to RTEMS. I would like to submit the BSP and YAFFS2 port to
>> RTEMS. The YAFFS2 license is GPL. I don’t know if that is OK with
>> RTEMS. I would like to do some robustness testing on the YAFFS2 port.
>> Does RTEMS have a test plan/procedure to validate new file systems?
> Congratulations on the BSP and port. Is the license OK on the BSP? Other
> email
> deals with the YAFFS2 license issue.
> There are POSIX tests which exercise files through the C library IO
> calls and
> should exercise all the functionality available through "normal" APIs. You
> would just have to arrange to have that mounted and the paths point to it.
> --joel
>> Kevin Kirspel
>> Opti Medical Systems
>> Electrical Engineer
>> 235 Hembree Park Drive
>> Roswell GA 30076
>> (ph) 770-510-4444 x4568
>> (fax) 770-510-4445
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
