MCF5329EVB BSP
Kirspel, Kevin kevin.kirspel at optimedical.com
Fri Oct 5 21:00:13 UTC 2007
There are no licensing issues with the BSP.  The port does require a change
to the gnu tool chain generation so that it generates a m68k-rtems for the
coldfire version 3 core (m5307 cpu).
Kevin Kirspel
Opti Medical Systems
Electrical Engineer
235 Hembree Park Drive
Roswell GA 30076
(ph) 770-510-4444 x4568
(fax) 770-510-4445
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: Friday, October 05, 2007 2:36 PM
To: Kirspel, Kevin
Cc: 'rtems-users at rtems.org'
Subject: Re: MCF5329EVB BSP
Kirspel, Kevin wrote:
> I have almost completed a port to RTEMS of the MCF5329EVB evaluation
> board from Freescale. With this BSP I had to port the YAFFS2 file
> system to RTEMS. I would like to submit the BSP and YAFFS2 port to
> RTEMS. The YAFFS2 license is GPL. I don't know if that is OK with
> RTEMS. I would like to do some robustness testing on the YAFFS2 port.
> Does RTEMS have a test plan/procedure to validate new file systems?
Congratulations on the BSP and port. Is the license OK on the BSP? Other
email
deals with the YAFFS2 license issue.
There are POSIX tests which exercise files through the C library IO
calls and
should exercise all the functionality available through "normal" APIs. You
would just have to arrange to have that mounted and the paths point to it.
--joel
> Kevin Kirspel
> Electrical Engineer
> Roswell GA 30076
> (fax) 770-510-4445
> rtems-users mailing list
> rtems-users at rtems.com
