MCF5329EVB BSP
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Oct 5 21:11:05 UTC 2007
Till Straumann wrote:
>>> Just a reminder that the filesystem framework currently is not
>>> thread-safe!
>> Your outstanding patches are in the queue for 4.9.
> IIRC my patches don't cover making the FS framework thread-safe.
I wanted time to analyze the problems you were reporting and
deal with them at a leisurely pace. That's one of the reasons I
went ahead and cut a 4.8 branch without adding them.
The other reason was that that it hasn't been a major problem
for all these years so one more release cycle wasn't a big deal.
--joel
> T
>> --joel
>>> T.
>>>> Kirspel, Kevin wrote:
>>>>> I have almost completed a port to RTEMS of the MCF5329EVB
>>>>> evaluation board from Freescale. With this BSP I had to port the
>>>>> YAFFS2 file system to RTEMS. I would like to submit the BSP and
>>>>> YAFFS2 port to RTEMS. The YAFFS2 license is GPL. I don’t know if
>>>>> that is OK with RTEMS. I would like to do some robustness testing
>>>>> on the YAFFS2 port. Does RTEMS have a test plan/procedure to
>>>>> validate new file systems?
>>>> Congratulations on the BSP and port. Is the license OK on the BSP?
>>>> Other email
>>>> deals with the YAFFS2 license issue.
>>>> There are POSIX tests which exercise files through the C library IO
>>>> calls and
>>>> should exercise all the functionality available through "normal"
>>>> APIs. You
>>>> would just have to arrange to have that mounted and the paths point
>>>> to it.
>>>> --joel
>>>>> Kevin Kirspel
>>>>> Opti Medical Systems
>>>>> Electrical Engineer
>>>>> 235 Hembree Park Drive
>>>>> Roswell GA 30076
>>>>> (ph) 770-510-4444 x4568
>>>>> (fax) 770-510-4445
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.com
>>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
