Possible error in C User's Guide
Tue Oct 9 14:17:27 UTC 2007
Fabrício de Novaes Kucinskis wrote:
> Hello,
> I'd like to warn about a possible error in the RTEMS C User's Guide, version
> 4.7.1.
> I tried to create a partition and got an INVALID_SIZE status code. When
> debugging, I found out that this happens when the parameter "buffer_size" of
> "rtems_partition_create" wasn't a multiple of eight. If this is right, the
> RTEMS C User's Guide shall be fixed.
> In the User's Guide, page 129, it is written (twice) that the buffer_size
> and starting_address must be multiples of 4.
I will probably have to generate a test case to prove this to
myself but neither the code nor documentation clearly matches
what I think the rule is. :(
The rule is the buffer size should be a multiple of CPU_ALIGNMENT
which is >= sizeof(Chain_Node) where sizeof(Chain_Node) is 8 on a
target with 32-bit pointers.
Can you file a PR on this?
Thanks.
--joel
> Regards,
> Fabrício de Novaes Kucinskis - DEA / INPE
> Grupo de Supervisão de Bordo - SUBORD
> Divisão de Eletrônica Aeroespacial
> Instituto Nacional de Pesquisas Espaciais
> rtems-users mailing list
> rtems-users at rtems.com
