Problems building 4.8 branch
Eric Norum
norume at aps.anl.gov
Mon Oct 15 02:27:22 UTC 2007
I neglected to mention that the CVS head compiles fine -- perhaps the
4.8 branch needs to be re-cut?
On Oct 14, 2007, at 7:32 PM, Eric Norum wrote:
> I checked out the 4.8 branch of RTEMS. When I try to build it I get:
> m68k-rtems4.8-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../
> cpukit/../../../uC5282/lib/include -I/usr/local/rtems/src/cvs/
> rtems-4-8-branch/rtems/c/src/../../cpukit/libnetworking -DNOPOLL -
> DNOSELECT -D__BSD_VISIBLE -Wall -fasm -m528x -O2 -g -MT libc/libc_a-
> if_nameindex.o -MD -MP -MF libc/.deps/libc_a-if_nameindex.Tpo -c -o
> libc/libc_a-if_nameindex.o `test -f 'libc/if_nameindex.c' || echo '/
> usr/local/rtems/src/cvs/rtems-4-8-branch/rtems/c/src/../../cpukit/
> libnetworking/'`libc/if_nameindex.c
> /usr/local/rtems/src/cvs/rtems-4-8-branch/rtems/c/src/../../cpukit/
> libnetworking/libc/if_nameindex.c: In function 'if_nameindex':
> libnetworking/libc/if_nameindex.c:109: error: invalid application of
> 'sizeof' to incomplete type 'struct if_nameindex'
> libnetworking/libc/if_nameindex.c:113: error: invalid application of
> libnetworking/libc/if_nameindex.c:124: error: dereferencing pointer
> to incomplete type
> libnetworking/libc/if_nameindex.c:126: error: dereferencing pointer
> to incomplete type
> libnetworking/libc/if_nameindex.c:128: error: increment of pointer to
> unknown structure
> libnetworking/libc/if_nameindex.c:128: error: arithmetic on pointer
> to an incomplete type
> I configured the build with:
> /usr/local/rtems/src/cvs/rtems-4-8-branch/rtems/configure --prefix=/
> usr/local/rtems/rtems-4.8 --enable-cxx --disable-rdbg --enable-
> tests=samples --enable-networking --enable-posix --target=m68k-
> rtems4.8 --enable-rtemsbsp=uC5282
> The compiler is:
> rt> m68k-rtems4.8-gcc --version
> m68k-rtems4.8-gcc (GCC) 4.2.1
> I believe that this is a relatively recent addition to the network
> code. Did some header file get missed from the CVS commit?
> Eric Norum <norume at aps.anl.gov>
> Advanced Photon Source
> Argonne National Laboratory
> (630) 252-4793
> rtems-users mailing list
> rtems-users at rtems.com
(630) 252-4793
