http network example
Arquer Stephane
stephane.arquer at c-s.cnes.fr
Thu Oct 18 14:49:28 UTC 2007
I'm using the 4.7 branch.
Netdemo, netlink doesn't work to.
> -----Message d'origine-----
> De : rtems-users-bounces+stephane.arquer=c-s.fr at rtems.org
> [mailto:rtems-users-bounces+stephane.arquer=c-s.fr at rtems.org]
> De la part de Joel Sherrill
> Envoyé : jeudi 18 octobre 2007 15:02
> À : Arquer Stephane
> Cc : rtems-users at rtems.org
> Objet : Re: http network example
> Arquer Stephane wrote:
> > Hello,
> > I configured my 3c905 nic with elnk driver from th Rtems
> version 4.6.6
> > with the http example. It's working correctly. I installed
> Rtems 4.7.1
> > and the http execution is frozen after the
> > message: "etherlink: unit elnk1 driver attached".
> > My configure parameters are :
> > #define TEST_INIT
> > #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
> > #define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
> > #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
> > #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> > #define CONFIGURE_EXECUTIVE_RAM_SIZE (512*1024)
> > #define CONFIGURE_MAXIMUM_SEMAPHORES 20
> > #define CONFIGURE_MAXIMUM_TASKS 20
> > #define CONFIGURE_MAXIMUM_TIMERS 5
> > #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 5
> > #define CONFIGURE_MICROSECONDS_PER_TICK 10000
> > #define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024)
> > #define CONFIGURE_INIT_TASK_PRIORITY 120
> > #define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
> > RTEMS_NO_TIMESLICE | \
> > RTEMS_NO_ASR | \
> RTEMS_INTERRUPT_LEVEL(0))
> > Is there something else to add for this version ?
> If you are using the 4.8 branch or CVS head and didn't edit
> the Makefile, then there should be messages as init.c starts
> the ftpd and simple httpd. Then it just waits for you to
> browse to it.
> I assume that netdemo worked at this point. If it didn't,
> then it could just be a network issue.
> --joel
> --joel
> > Stephane.
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
