sp tests with MP enabled fails
    Philippe Simons
    loki_666 at fastmail.fm
    Sun Sep  9 11:29:42 UTC 2007
I'm working on two bsp for the gp2x (arm920t + arm940t).
I'm already able to run two separate instances of rtems on both cpu.
but when i enable multiprocessing, nothing is working.
mp-tests hangs during shm init i guess(i'm using polled mode)
but even sp-tests fails now.
they data-abort somewhere in the begining of _Objects_MP_Close function.
I'dont have JTAG cable to debug, but if you need more info should be
able to printk.
I'd like to sort out this data-abort issue first.
TIA
Philippe
http://www.fastmail.fm - One of many happy users:
  http://www.fastmail.fm/docs/quotes.html
