makefile problem
阎淼 yanmiaobest at gmail.com
Wed Sep 12 08:50:39 UTC 2007
Hi,
I forgot to modify the preinstall.am, and the header files failed to
get into my building directory.  After I did that, it works.
thank you for your reply!
2007/9/12, Chris Johns <chrisj at rtems.org>:
> 阎淼 wrote:
> > Hi,
> >    I add test .c file into cpukit/score/src,
> >    and test.h file and test.inl file into cpukit/inlude/rtems/score
> > cpukit/inline/rtems/score,
> > then I update makefile.am, and run automake.
> > but when building the source, there is an error:
> >  error: rtems/score/test.h : no such file or directory
> > my rtems version is 4.7.1
> > what did I miss ?
> Hard to say if you do not detail what the changes are.
> Did you bootstrap the directory again ?
> Regards
> Chris
