No subject
André Neves
andre-c-neves at criticalsoftware.com
Wed Sep 12 11:20:05 UTC 2007
Hi all.
I cave in and admit that the system outsmarted me.
Here goes newbie question. :)
Compiling RTEMS for a LEON2 simulator in a Linux (Ubuntu 7.04) machine.
autoconf 2.61, automake 1.10, gcc 4,1,2.
I'm in the last step of the compilation described in the wiki's Quick Start:
> cd rtems
> export PATH=/opt/rtems-4.8/bin:$PATH
> ./bootstrap
> cd ..
> mkdir b-sis
> cd b-sis
> ../rtems/configure --target=sparc-rtems --enable-rtemsbsp=sis
--enable-tests=samples --disable-posix --disable-itron
> make
Doing 'make all'.
> Making all in capture
> make[5]: Entering directory
`/home/ac-neves/workdir/sparc-rtems/c/leon2/testsuites/samples/capture'
> sparc-rtems-gcc -B../../../../../leon2/lib/ -specs bsp_specs -qrtems
-mcpu=cypress -msoft-float -O2 -g -o capture.exe init.o test1.o
> ../../../../../leon2/lib/librtemscpu.a(libposix_a-usleep.o): In function
`usleep':
> /home/ac-neves/workdir/sparc-rtems/c/leon2/cpukit/posix/../../../../../../rtems-leon2/c/src/../../cpukit/posix/src/usleep.c:29:
undefined reference to `nanosleep'
> collect2: ld returned 1 exit status
> make[5]: *** [capture.exe] Error 1
> make[5]: Leaving directory
I've been trying to fix it myself, but failed to understand how everything
is well except for nanosleep.
Can something not have been included properly?
Any pointers?
Thank you. :)
Andre´ Neves
