_Heap_Allocate_aligned return the same address?
Wed Sep 12 20:17:06 UTC 2007
Sergei Organov wrote:
> "阎淼" <yanmiaobest at gmail.com> writes:
>> Hi,
>>    I am using rtems-4.7.1 on i386-qemu, I called
>> _Heap_Allocate_aligned  twice, but the return address are the same.
>> here is my code:
>>    char buf[4096 * 10];
>>    #define PAGE_SIZE 4096
>>    void f()
>>         Heap_Control the_heap;
>>         _Heap_Initialize( &the_heap, (void *)buf,  4096 * 10,  CPU_ALIGNMENT);
>>          void  *p = _Heap_Allocate_aligned( &the_heap, 4096, PAGE_SIZE);
>>          void  *g = _Heap_Allocate_aligned( &the_heap, 4096, PAGE_SIZE);
>>          printf("0x%x\n", p );
>>          printf("0x%x\n", g );
>> and the output is:
>>   0x125000
>>   0x125000
>>  is somthing wrong here?
> I've created a new PR1258 for this issue:
> <https://www.rtems.org/bugzilla/show_bug.cgi?id=1258>
And you attached a PR.  I committed it to the 4.7 branch and CVS head.
For those in the back row, it does not apply to the 4.6 branch since that
had different heap code.
Thanks.
--joel
> -- Sergei.
> rtems-users mailing list
> rtems-users at rtems.com
