How to build tests under testsuites/sptests?
Ian Jiang ianjiang.cn at gmail.com
Tue Sep 18 09:06:50 UTC 2007
I am using Suse-10.2 and the rtems developing tools was built from source RPMS from
http://www.rtems.com/ftp/pub/rtems/linux/4.7/suse/10.2/SRPMS/
Now I want to build tests under testsuites/sptests. The following configuration is used:
ian at IanVM-1:~/rtems/b-rtems> ../../src/rtems-4.7.1/configure --target=arm-rtems4.7 --enable-posix --enable-cxx --enable-rtemsbsp=edb7312 --enable-tests --prefix=/home/ian/rtems/rtemsdocs-4.7.1
But I have got only /home/ian/rtems/b-rtems/arm-rtems4.7/c/edb7312/testsuites/samples after "make all".
Any suggestion is appreciated!
Best wishes!
Ian Jiang
2007-09-18 16:48:07
