Makefile.inc doesn't define CXX / CXX_FOR_TARGET
Tue Sep 18 17:56:46 UTC 2007
Keith Robertson wrote:
> Hi.
> I'm trying to use, what I believe to be, the recommended method of
> compiling third party apps against rtems (in this case norm).  However,
> the Makefile.inc in my $RTEMS_MAKEFILE_PATH doesn't define a CXX.
Just to repeat the party line.  There is no obligation to use those
Makefiles for external applications.  They just make it easier
for RTEMS examples to be built outside the tree.
> It has CC, AS, LD, NM, AR, SIZE, and OBJCOPY, should it not also provide
> a CXX?  Or am I going about this the wrong way...?  I'd like the
> Makefile I submit to norm to be generic, so I believe it is correct that
>   the Makefile.inc should provide this information?
Seems reasonable.  Done in CVS.  Grab it from there.
> Makefile.inc on pc386 from rtems cvs head appended below:
> # BSP specific settings. To be included in application Makefiles
> RTEMS_BSP = pc386
> prefix = /home/keithr/work/volkano/build/Core/rtems48
> exec_prefix = /home/keithr/work/volkano/build/Core/rtems48/i386-rtems4.8
> CC_FOR_TARGET = i386-rtems4.8-gcc --pipe
> AS_FOR_TARGET = i386-rtems4.8-as
> AR_FOR_TARGET = i386-rtems4.8-ar
> NM_FOR_TARGET = i386-rtems4.8-nm
> LD_FOR_TARGET = i386-rtems4.8-ld
> SIZE_FOR_TARGET = i386-rtems4.8-size
> OBJCOPY_FOR_TARGET = i386-rtems4.8-objcopy
> CC= $(CC_FOR_TARGET)
> AS= $(AS_FOR_TARGET)
> LD= $(LD_FOR_TARGET)
> NM= $(NM_FOR_TARGET)
> AR= $(AR_FOR_TARGET)
> SIZE= $(SIZE_FOR_TARGET)
> OBJCOPY= $(OBJCOPY_FOR_TARGET)
> export CC
> export AS
> export LD
> export NM
> export AR
> export SIZE
> export OBJCOPY
> RTEMS_CUSTOM = $(prefix)/make/custom/$(RTEMS_BSP).cfg
> PROJECT_ROOT = $(prefix)
> RTEMS_USE_OWN_PDIR = no
> RTEMS_HAS_POSIX_API = yes
> RTEMS_HAS_ITRON_API = yes
> RTEMS_HAS_CPLUSPLUS = yes
> export RTEMS_BSP
> export RTEMS_CUSTOM
> export PROJECT_ROOT
> # FIXME: The following shouldn't be here
> RTEMS_ROOT = $(PROJECT_ROOT)
> export RTEMS_ROOT
> Thoughts?
> Keith
> rtems-users mailing list
> rtems-users at rtems.com
