RTEMS/GCC C++ delete structure that contains a class
Brett Swimley brett.swimley at aedbozeman.com
Tue Sep 18 18:01:07 UTC 2007
Hi All,
I may be violating "best practice" coding, but I have a question
regarding the RTEMS delete operator.
Consider something like:
class foo
public:
 foo() { p = new unsigned char[10]; }
virtual ~foo() { delete[] p; }
unsigned char* p;
I understand that calling new in a class constructor may not be the best
coding practice, but...
Now consider a structure that contains the class:
typedef struct foo_info
foo fooinfo;
int i;
} FOO_INFO;
Now, given this code...
q = new FOO_INFO;
q->i = 0;   // For example...
delete q;
It appears that the destructor for foo never gets called.  Tracing into
the delete operator, it is just calling free.
Is this normal behavior?  It appears that if I change my structure
declaration into a class definition, the expected behavior occurs.  If
this is what needs to be done, I certainly can do this.
Should deleting a structure that contains a class invoke the class
destructor?
Thanks in advance.
Brett
