how to make the building process more easily?
rtems skyeye
skyeye.rtems at gmail.com
Wed Sep 19 03:18:04 UTC 2007
hi,
I modify the source codes in RTEMS-SRC-DIR, and I configure & make in
RTEMS-BUILD-DIR.
If I modified a .c file, I can only make in RTEMS-BUILD-DIR.
But If I modified a .h file, I have to copy the file into correct path in
RTEMS-BUILD-DIR.
The .h file is copied to in RTEMS-BUILD-DIR, but the .c file is linked in
RTEMS-BUILD-DIR.
Is there any methods to make the .h also linked in RTEMS-BUILD-DIR?
Please give me some helps!
Regards
SkyEye.RTEMS
URL: <http://lists.rtems.org/pipermail/users/attachments/20070919/2d42715c/attachment.html>
