RES: RES: Why not a directive rtems_clock_set (rtems_clock_time_value)?
Fabrício de Novaes Kucinskis fabricio at dea.inpe.br
Wed Sep 19 17:08:54 UTC 2007
Joel, thanks for the path, but I think there's something more.
I applied the patch and rebuilt RTEMS, but the clock_settime function was
not compiled.
Do I have to enable posix (currently I use --disable-posix) in configure? I
undestood that this would not be necessary with this patch.
Regards,
Fabrício.
-----Mensagem original-----
De: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Enviada em: terça-feira, 18 de setembro de 2007 17:12
Para: Fabrício de Novaes Kucinskis
Cc: RTEMS - Mailing List
Assunto: Re: RES: Why not a directive rtems_clock_set
Fabrício de Novaes Kucinskis wrote:
>> History.  Plus more people need to get the time in different formats
>> than need to set it in different formats.
>> At this point in time, I have grown to dislike the enum overloaded
>> style of clock_get.
> I'd ask for an enum overloaded style of clock_set, but forget it... :)
> Ok, so if I need a clock set function using the rtems_clock_time_value, I
> have to create one. Just to ease my work, let me ask: is there an internal
> "_Seconds_to_TOD" function or something alike?
Try this patch to cpukit/posix/Makefile.am and it should build
posix/src/clocksettime.c.  That code is setup to do the conversion you
want.
Remember to bootstrap.
Whether this patch should be in all builds is open to user discussion
but POSIX defines the routine you want.
--joel
> Regards,
> Fabrício.
> Enviada em: terça-feira, 18 de setembro de 2007 12:08
> Assunto: Re: Why not a directive rtems_clock_set
>> Hello all,
>> I'm wondering here: if we have ways to get the RTEMS clock counter in the
>> "rtems_time_of_day", "rtems_clock_time_value" and "rtems_interval"
> formats,
>> why there is just one way to set it (with "rtems_time_of_day")?
> style of clock_get.  It makes it harder to have strict typing and
> that style of routine tends to reference more support code than
> any particular user needs.  Thus it leads to code getting pulled in
> that you won't necessarily use.  So I would lean to a new small
> routine.  It's all up to users though.
>> Why don't we have a way to set the clock in "rtems_clock_time_value"? As
> the
>> counting is in ticks, I can't see any technical issue here that prevents
>> this.
> There is this from POSIX:
> int clock_settime(
>   clockid_t              clock_id,
>   const struct timespec *tp
> Some of the code in posix/src is enabled all the time (e.g. sleep and
> friends).  Maybe  it makes sense to enable this one also.
>> Regards,
>> Fabrício de Novaes Kucinskis - DEA / INPE
>> Onboard Data Handling Group - SUBORD
>> Aerospace Electronics Division
>> Brazilian National Institute for Space Research
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
