Zero copy TCP
Paul Black paul.black at oxsemi.com
Thu Sep 20 15:32:26 UTC 2007
I've been looking at the RTEMS code to see if there's a zero copy TCP
interface or if it would be easy to add one.
The code in c/src/nfsclient/src/sock_mbuf.c seems to be what I'm looking
for. The code that uses it (rpcio.c) uses it with UDP sockets. Has
anyone tried using this code with TCP sockets? Is it likely that this
will work with a TCP socket?
Cheers
Paul
