3c905 Nic configuration
Tue Sep 25 17:19:05 UTC 2007
Karel Gardas wrote:
> Hello,
> IIRC 3c905x is different from 3c509. Please use xl driver for your card
> and it should work well.
Isn't one ISA and the other PCI?
--joel
> Cheers,
> Karel
> Stéphane ARQUER wrote:
>> Hello,
>> I'm trying to configure the network interface 3c905c-TXM with the pc386
>> bsp of rtems 4.6.6.
>> I read in the wiki that someone used this reference in september 2005 but
>> there is no details on the driver to use.
>> On the other hand, I'm working with a 3c509B-tpo card, I try to execute
>> the network examples and when the card seems to be configured:
>> -->     3C509: attach() is complete
>> there are the error messages:
>> -->     Can't bring ep up: No such device or adress
>> -->     Can't set default route: No such process
>> -->     Can't get host adress
>> You 'll find attached the networkconfig.h file.
>> If anyone has a tip ?
>> Thanks in advance for your help.
>> Regards.
>> SA
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
