how to test my rtems application program?
Thu Sep 27 16:07:44 UTC 2007
Till Straumann wrote:
> I have used grub and etherboot to boot i386-rtems
> applications. With both of them I used the ELF file,
> not the one generated by bin2boot.
Now that you say that, I have done the same thing also.
--joel
> YMMV
> -- Till
> Joel Sherrill wrote:
>> alwyn lee wrote:
>>> hi,
>>> I have a problem that  when I finish building the rtems system, I
>>> use it to make a user program such as the examples rtems supplied.
>>> my target bsp use pc386.
>>> I use the pc386 grub image from the rtems.com , but i find that the
>>> program format is netbsd-a.out ,my program format is multiboot-elf.
>>> is it the reason that my program can not run in that grub ?
>>> and how to test my program , or is there a simulator to test my
>>> program for pc386?
>>> I'm so confused about the problem.
>> The pc386 BSP make procedure does some magic transformations on the
>> ELF file produced by directly linking.  If you want the commands used
>> when producing the RTEMS samples you will see some steps involving
>> an objcopy and a bin2boot.  You have to do those steps on your program.
>> You will have to provide more details to know what you are doing wrong.
>> But the pc386 BSP does require some extra streps to get from linked
>> ELF to bootable image.
>> --joel
>>> who can help me? thanks a lot !
>>>                                  alwyn
>>> alwyn lee
>>> alwyn116 at hotmail.com (Messenger)
>>> alwyn116 at yahoo.com.cn (Mail)
>>> Shape Yahoo! in your own image. Join our Network Research Panel
>>> today!
>>> <http://us.rd.yahoo.com/evt=48517/*http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7>
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
