3c905 Nic configuration
Fri Sep 28 13:13:47 UTC 2007
Stéphane ARQUER wrote:
> Hello,
> My card seems not to be recognized correctly on the pci bus.
>   "Etherlink: No Etherlink device found "
Check the PCI Id of your card versus the list of PCI Ids
it checks for.    Often cards get new revisions and the Id
changes and the RTEMS driver doesn't know it yet.
--joel
> sA
> Le 27/9/2007, "Joel Sherrill" <joel.sherrill at oarcorp.com> a écrit:
>> How about elink1? You are naming the specific interface,
>> not the driver as a whole.
>> --joel
>>> Hello,
>>> Le 25/9/2007, "Joel Sherrill" <joel.sherrill at oarcorp.com> a écrit:
>>>> Back to the list. Everyone needs to pitch in on this one. :-D
>>>>> -----Message d'origine-----
>>>>> De : Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>>>>> Envoyé : mardi 25 septembre 2007 19:19
>>>>> À : Karel Gardas
>>>>> Cc : Stéphane ARQUER; RTEMS users
>>>>> Objet : Re: 3c905 Nic configuration
>>>>> Karel Gardas wrote:
>>>>>> Hello,
>>>>>> IIRC 3c905x is different from 3c509. Please use xl driver for your
>>>>>> card and it should work well.
>>>>> Isn't one ISA and the other PCI?
>>>>> Yes, the 3c509B-tpo is an ISA and the 3c905c-TXM a PCI.
>>>>> Where do you find the xl driver ?
>>>> The .c file is in c/src/libchip/network/elnk.c.  I do not see a .h file
>>>> that is for
>>>> you to include in your networkconfig. :(
>>>> Prototype:
>>>> int
>>>> rtems_elnk_driver_attach (struct rtems_bsdnet_ifconfig *config, int attach)
>>> I created a simple one with only the prototype mentionned above and I
>>> added these lines in the BSP.h file:
>>> #define BSP_ELNK_NETWORK_DRIVER_NAME   "elnk"
>>> #define BSP_ELNK_NETWORK_DRIVER_ATTACH  rtems_elnk_driver_attach
>>> and I obtain the following error message:
>>> Bad network driver name 'elnk'
>>> Can't bring elnk up: No such device or address
>>> Can't set default route: No such process
>>> Can't get host address
>>> Another problem is to modify the file elnk.c, I'm not able to compile it
>>> after modifications to update it il the librtemsbsp.a file. I use this
>>> commande to do it :
>>> i386-rtems-gcc --pipe -B/opt/rtems-4.6/i386-rtems/pc386/lib/ -specs
>>> bsp_specs -qrtems -g -Wall -04 -c -o elnk.o elnk.c
>>> If you have a tip.
>>> Thanks.
>>> Stephane.
>>>> It would be nice to have the user .h file that applications include
>>>> when configuring the driver.
>>>> --joel
>>>>> --joel
>>>>>> Cheers,
>>>>>> Karel
>>>>>>> Hello,
>>>>>>> I'm trying to configure the network interface 3c905c-TXM with the
>>>>>>> pc386 bsp of rtems 4.6.6.
>>>>>>> I read in the wiki that someone used this reference in september 2005
>>>>>>> but there is no details on the driver to use.
>>>>>>> On the other hand, I'm working with a 3c509B-tpo card, I try to
>>>>>>> execute the network examples and when the card seems to be configured:
>>>>>>> -->     3C509: attach() is complete
>>>>>>> there are the error messages:
>>>>>>> -->     Can't bring ep up: No such device or adress
>>>>>>> -->     Can't set default route: No such process
>>>>>>> -->     Can't get host adress
>>>>>>> You 'll find attached the networkconfig.h file.
>>>>>>> If anyone has a tip ?
>>>>>>> Thanks in advance for your help.
>>>>>>> Regards.
>>>>>>> SA
>>>>>>> _______________________________________________
>>>>>>> rtems-users mailing list
>>>>>>> rtems-users at rtems.com
>>>>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>> Stéphane ARQUER
>>> CSSI - Division Aéronautique, Logiciels Embarqués
>>> email: stephane.arquer at c-s.fr
> Stéphane ARQUER
