Undefined reference to DEBUG_puts in RTEMS 4.8
Daniel Hellstrom daniel at gaisler.com
Mon Sep 17 10:45:33 UTC 2007
Hi,
Yes, I have seen the DEBUG_puts error and fixed it. It is now part of
the official CVS too.
Next release will include a fix for this.
I haven't tested but I think you could solve the linking problem in the
meanwhile by declaring DEBUG_puts in you application like:
void DEBUG_puts(
char *string
printk(string);
or
void DEBUG_puts(
char *string
Thank you for reporting this,
Daniel Hellstrom
Aitor.Viana.Sanchez at esa.int wrote:
> Hi all,
> i have an error with
> sparc-rtems-4.7.99.2-gcc-4.2.1-1.0.0-linux.tar.bz2 that I got from
> Gaisler research. The RTEMS version within this package is 4.8 .
> I got a piece of SW already compiled and proved with RTEMS 4.6. When I
> updated to the 4.8 RTEMS version and tried to re-compile the SW I got
> a linker error:
> /opt/rtems-4.8/sparc-rtems/leon2/lib/librtemsbsp.a(libnetchip_a-smc91111.o):
> In function `lan91cxx_interrupt_handler':
> /home/daniel/reps/rtems48_rep/rtems-4.8-build/sparc-rtems/c/leon2/libchip/../../../../../rtems-4.8/c/src/libchip/network/smc91111.c:121:
> undefined reference to `DEBUG_puts'
> The strange thing here is that the path /home/daniel/reps...etc etc
> does not exist in my machine. I think maybe this is an error of the
> compiled version I got.
> any clue?
> *rtems skyeye <skyeye.rtems at gmail.com>*
> Sent by: rtems-users-bounces+aitor.viana.sanchez=esa.int at rtems.org
> 03/09/2007 16:50
> To
> 	rtems-users at rtems.org, yanmiaobest at gmail.com
> cc
> Subject
> 	SPAM:**** Fwd: design Real-Time Process in RTEMS
> hi,
> Good idea!
> I think we can first realize the initial VM support in RTEMS.
> because there are already some page support funcs in rtems X86 port.
> then we can try syscall,....
> ---------- Forwarded message ----------
> From: *阎淼* <_yanmiaobest at gmail.com_ <mailto:yanmiaobest at gmail.com>>
> Date: Sep 3, 2007 11:21 AM
> Subject: Re: design Real-Time Process in RTEMS
> To: rtems skyeye <_skyeye.rtems at gmail.com_
> <mailto:skyeye.rtems at gmail.com>>
> Hi:
> I have been thinking about it too.
> here is what I think:
> 1. page routine should be created to support page manipulations(
> page table operation, TBL, page allocate, set page state ...)
> 2. identify all system call routines
> 3. create entry points and exit points for system call
> 4. adjust context switch ralated routine
> 5. add privilege transition code
> best regards!
> 2007/8/31, rtems skyeye <_skyeye.rtems at gmail.com_
> <mailto:skyeye.rtems at gmail.com>>:
> > hi,
> > VxWorks 6.x have the Real-Time Process (RTP) extension.
> > I think we also can implement the RTP in RTEMS.
> > The Idea is :
> > 1 RTP contains 1~n user-level rtems-task, and process the
> > virtual memory related things.
> > 2 the mapping relation of virtual memory :phyiscal memory is 1:1
> > 3 the user-level task in RTP can access kernel function
> > by syscall
> > 4 the user-level tasks and the kernel-level tasks are in the same
> > scheduling strategy.
> > the advantage of RTP is:
> > 1 the crash of user-level tasks in RTP can not destroy user-level
> > tasks in other RTP and the kernel.
> > 2 compatible with the old task model.
> > 3 the context switch is faster than that of general OS (such as linux)
> > anyone have some advices on RTP in RTEMS?
> > Regards
> > skyeye.rtems
> > rtems-users mailing list
> > _rtems-users at rtems.com_ <mailto:rtems-users at rtems.com>
> > _http://rtems.rtems.org/mailman/listinfo/rtems-users_
