RTEMS/GCC C++ delete structure that contains a class
Brett Swimley
brett.swimley at aedbozeman.com
Thu Sep 20 20:05:06 UTC 2007
Chris,
Thanks for the reply.
Upon further investigation, I determined that the class destructor was
being called. By placing appropriate print instructions inside of the
destructor, rather than relaying on stepping through the code with a
debugger, I determined that the behavior was as expected.
Brett
Chris Johns wrote:
> Yes I think it should if the destructor does need to do something.
> What actually ends up in the code depends on what happens around the
> code and its use. You have asked the code to be inlined.
> It is difficult to determine if anything is actually broken without
> the tools version and target. I built an example of the code on Fedora
> 7 without optimisation options and inspecting the code showed it had
> the correct calls.
