What is "no" application? nm?
Leon Pollak leonp at plris.com
Tue Apr 1 08:20:46 UTC 2008
> OK, let's bring this fruitless discussion to an end:
> run
> rpm -qa 'rtems-4.8-*powerpc*'
> echo $PATH
> and show us the results.
Ralf, I am using (successfully :)) RTEMS since 1996. At that time there was no
rpm support and since that I downloaded tgz/rpms and unpack them manually,
putting into the required directories.
OK, I understand now that it is so importand. I shall spent some time to
rebuild everything with rpms to return to the "main stream"...:)
Thank you!
Leon
