Cpu_table was Re: What is "no" application? nm?
Tue Apr 1 13:18:44 UTC 2008
>> For example, there was no usage of Cpu_table.exceptions_in_RAM in none of
>> mpc8xxx BSPs.
> This has nothing to do with your current issue.
> The powerpc guys (Thomas, Till, Joel) are the persons to answer.
Right.  The Cpu_table is gone after RTEMS 4.8.  Most of the
fields were portable across all ports.  A few fields were
device driver configuration and a few configured
behavior in cross-BSP files.
I don't remember the resolution of this one in particular
but whereever it was set in 4.8 will likely have a similarly
named variable.  This one seems to be a shared code configuration
variable.
> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
