DHCP: renewal when cable is plugged out/in
Arnout Vandecappelle
arnout at mind.be
Thu Apr 3 13:42:22 UTC 2008
Hoi,
I have an RTEMS-based system which normally is not connected to the
(Ether)network, but occasionally a user comes a long and plugs in a
cable. I need DHCP to get a new address whenever the network cable is
plugged in, even if it's previous lease hasn't expired yet. I also need
DHCP to fall back to a statically configured address if no reply comes.
My questions:
* does anyone have these features already? I expect not, so
* any suggestions on how to implement the network cable plug-in
detection? My Ethernet driver detects cable (dis)connects, how should
these be propagated to the DHCP task?
- By setting the struct ifnet's if_flags and have the DHCP task poll
on them; or
- by sending an event to the DHCP task; or
- by configuring a hook similar to the network taps, and having the
DHCP task register a function to it; or
- by calling BSDnet's if_down() from the driver, make the DHCP task
listen on the routing input socket.
I guess the last option is the best, but it requires a bit of BSDnet
insight...
And one final question: is it OK to make changes to BSDnet itself, or
is that to be avoided because it makes tracking the real BSDnet
development more difficult?
Regards,
Arnout
Arnout Vandecappelle arnout at mind be
Senior Embedded Software Architect +32-16-286540
Mind Embedded Development (an Essensium division)
