Building difficulties under OSX
Alan Cudmore
Alan.P.Cudmore at nasa.gov
Fri Apr 4 02:42:25 UTC 2008
I have attached the scripts I use to build a toolchain, then to build
RTEMS on OS X, linux and cygwin
The scripts make certain assumptions about the location of the
source, and they operate on the source that has been downloaded and
patched. Just edit them to match your environment, or use it as a
reference.
There are other scripts available such as the one on this page:
http://www.aps.anl.gov/epics/base/RTEMS/tutorial/node6.html
I was planning on expanding my scripts to download and patch the
source code that I needed as well.
Of course I don't see any Google Summer of Code proposals for Mac OS
X tool packaging yet :)
Alan
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20080403/29e9ee5c/attachment.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20080403/29e9ee5c/attachment-0001.obj>
On Apr 3, 2008, at 7:50 PM, Nigel Spon wrote:
> On 04/04/2008, at 10:56 AM, Daron Chabot wrote:
>> I'm going to assume that ./rtems-4.8.0/configure is just a typo, and
>> that the actual command was ../rtems-4.8.0/configure
> Ah, yes, lost the first char there somehow.
>> /tmp/trial/bin should contain your cross-platform tools (powerpc-
>> rtems4.8-gcc, powerpc-rtems4.8-ld, etc)
> Is this before I call make, or after? I can't tell if the --prefix
> option specifies where to find the tools, or where RTEMS will be
> built. The documentation says its the install-point, but it doesn't
> say of what. I'll try making it where the tools are and see what
> happens...
> ?The would-be sorcerer alone has faith in the efficacy of pure
> knowledge; rational people know that things act of themselves or not
> at all.?
> Michael Hamel
> ADInstruments Ltd, Dunedin, NZ
> rtems-users mailing list
> rtems-users at rtems.com
