Execution time different
Fri Apr 4 16:18:46 UTC 2008
Arquer Stephane wrote:
> Hello,
> I use a leon2  cpu and I have two way to load the code.
> The first one is grmon and the other is Redboot with a binary file
> generated by sparc-rtems4.7-objcopy -O binary file.elf file.bin.
> I don't have the same behaviour with the same code.
> With grmon, a calcul function last 120ms
> With redboot, this function last 340ms
> I check MCFG2 :
> Grmon:    03801460
> Redboot: B0801460
> And I modified it in grmon but the time is always 120ms.
> Does anyone know what is initialise by grmon which is not done by
> Redboot ?
Is caching enabed in both configurations?
--joel
> Thanks for help.
> sa
> rtems-users mailing list
> rtems-users at rtems.com
