No subject
fall4ufeng
fall4ufeng at gmail.com
Sun Apr 6 12:10:43 UTC 2008
hi,all:
when i debug the netcard driver, the program hang when it finish the transmitting progress ( the first arp packet ). I found that it can enter the isr routine , and i got the following information in the gdb
Program received signal SIGINT, Interrupt.
0x40006c28 in _CPU_Thread_Idle_body ()
at ../../../../../../../../../rtems-4.6.6-1.0.0/c/src/lib/libbsp/sparc/arc810/startup/setvec.c:69
69 LEON_REG.Power_Down = LEON_REG.Power_Down; /* make sure on load follows store to power-down reg */
(gdb) bt
#0 0x40006c28 in _CPU_Thread_Idle_body ()
#1 0x4003cbf8 in _Thread_Handler ()
at ../../../../../../rtems-4.6.6-1.0.0/cpukit/score/src/threadhandler.c:123
#2 0x4003cb0c in raw_disconnect (rp=0x1)
at ../../../../../../rtems-4.6.6-1.0.0/cpukit/libnetworking/net/raw_cb.c:130
#3 0x4003cb0c in raw_disconnect (rp=0x1)
Previous frame identical to this frame (corrupt stack?)
so ,anyone can help ? thanks a lot .
2008-04-06
fall4ufeng
URL: <http://lists.rtems.org/pipermail/users/attachments/20080406/36bc7f12/attachment.html>
