Hard float compilation pb
Ralf Corsepius ralf.corsepius at rtems.org
Mon Apr 7 10:21:18 UTC 2008
On Mon, 2008-04-07 at 10:22 +0200, Arquer Stephane wrote:
> Hello,
> When I compile paranoia sample with -mhard-float option with rtems
> 4.6.6, the test passes correctly.
> When I do it with rtems 4.7.1 or .2 the test fails If I compile with
> hard-float .
> Does anyone have an idea to solve this problem ?
Not before you tell us more details;)
Firstly, you could tell us which target you are using.
Secondly, you could tell us which BSP you are using.
Thirdly, you could tell use which toolchains on which hosts you are
using.
Finally, if I were you I would not use rtems-4.6 nor rtems-4.7, but use
rtems-4.8.
Ralf
