Intermixing source code with disassembly
Teng Chee Wan Philip
tcheewan at ntu.edu.sg
Tue Apr 8 01:15:02 UTC 2008
Yes, I did.
________________________________
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: Mon 4/7/2008 10:43 PM
To: Teng Chee Wan Philip
Cc: Chris Johns; rtems-users at rtems.com
Subject: Re: Intermixing source code with disassembly
Teng Chee Wan Philip wrote:
> Thanks, Chris. I tried the following. The line number gets inserted
> (That is a positive step. :) ) but the disassembled code is still not
> intermixed with the application source.
> sparc-rtems4.8-objdump -D --line-numbers --source --demangle app.exe
> There is some differences between code disassembled for the RTEMS OS and
> the application. I extracted part of it out for illustration.
Did you compile your application code with the -g option?
> Disassembled code intermixed with RTEMS source
> 0200ddec <bsp_start>:
> bsp_start():
> C:/Msys/1.0/home/PhilipTeng/rtems-4.8/rtems-4.8.0/c/src/lib/libbsp/sparc
> /shared/bspstart.c:119
> * This routine does the bulk of the system initialization.
> void bsp_start( void )
> 200ddec: 9d e3 bf 98 save %sp, -104, %sp
> /shared/bspstart.c:137
> * This should be enough interrupt stack.
> Cpu_table.interrupt_stack_size = CONFIGURE_INTERRUPT_STACK_MEMORY;
> work_space_start =
> 200ddf0: 03 00 80 01 sethi %hi(0x2000400), %g1
> 200ddf4: 23 00 8b 41 sethi %hi(0x22d0400), %l1
> 200ddf8: da 00 63 c0 ld [ %g1 + 0x3c0 ], %o5
> 200ddfc: 82 14 63 dc or %l1, 0x3dc, %g1
> 200de00: c8 00 60 04 ld [ %g1 + 4 ], %g4
> /shared/bspstart.c:128
> * Set up our hooks
> * Make sure libc_init is done before drivers initialized so that
> * they can use atexit()
> Cpu_table.pretasking_hook = bsp_pretasking_hook; /* init libc, etc.
> 200de04: 03 00 80 37 sethi %hi(0x200dc00), %g1
> 200de08: 82 10 62 64 or %g1, 0x264, %g1 ! 200de64
> <bsp_pretasking_hook>
> 200de0c: 07 00 8b 41 sethi %hi(0x22d0400), %g3
> Disassembled code intermixed with line number but not source
> c:\msys\1.0\home\PhilipTeng\app/app.c:188
> 20013e4: 40 00 1b 78 call 20081c4 <canMastInit>
> 20013e8: 90 10 20 04 mov 4, %o0
> 20013ec: 80 a2 20 01 cmp %o0, 1
> 20013f0: 22 80 00 8b be,a 200161c <Init+0x43c>
> 20013f4: 11 00 80 8f sethi %hi(0x2023c00), %o0
> c:\msys\1.0\home\PhilipTeng\app/app.c:194
> 20013f8: 11 00 80 8f sethi %hi(0x2023c00), %o0
> 20013fc: 40 00 6f 15 call 201d050 <puts>
> 2001400: 90 12 23 d0 or %o0, 0x3d0, %o0 ! 2023fd0
> <__DTOR_END__+0x300>
> c:\msys\1.0\home\PhilipTeng\app/app.c:198
> 2001404: 40 00 18 8f call 2007640
> <ccsds_initialisePacketLayer>
> 2001408: 90 10 20 01 mov 1, %o0
> 200140c: 80 a2 20 01 cmp %o0, 1
> 2001410: 22 80 00 8b be,a 200163c <Init+0x45c>
> 2001414: 11 00 80 8f sethi %hi(0x2023c00), %o0
> -----Original Message-----
> From: Chris Johns [mailto:chrisj at rtems.org]
> Sent: Sunday, April 06, 2008 6:01 AM
> Cc: rtems-users at rtems.com
>> I was trying to disassemble my executable and intermix source code
> with
>> the disassembly, but objdump did not managed to find the source code.
>> Does anyone have any suggestions why this could be so? Are there any
>> limitations on objdump or specific way that objdump uses to search for
>> the source code?
>> $ sparc-rtems4.8-objdump -d -S app.exe
> You might want to check the Debugging Hints page in the Wiki:
> http://www.rtems.org/wiki/index.php/DebuggingHints#Symbolic_Debug_Inform
> ation
> http://www.rtems.org/wiki/index.php/DebuggingHints#GDB_Cannot_Find_My_So
> urce_Files
> Let us know if this does not help.
> Regards
> Chris
> rtems-users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20080408/dfa8c072/attachment.html>
