Adding New Hardware Interrupts
Robert S. Grimes rsg at alum.mit.edu
Tue Apr 8 13:58:19 UTC 2008
Hi all,
I am using the PowerPC/Virtex BSP to develop several cooperating
applications built on (physically) identical processor boards; however,
the boards are mated to different "analog I/O" boards to support the
different mix of external actuators and sensors.  So, the FPGA
configurations are different for each instance, though they share a core
set of peripherals (e.g. interrupt controller, console I/O, networking,
two SPI controllers, etc.); each instance adds additional peripherals,
as needed.
My ideal approach here is to only deal with one BSP for all processors,
for the obvious reasons, and add support for the additional devices at
the "application level".  This seems rather straightforward, until the
issue of interrupts come in.
Is the interrupt manager (i.e. rtems_interrupt_XXX() family of
functions) the way to go here?  How do I determine the
rtems_vector_number for the interrupt_catch() function?
My suspicion is that in "normal" cases, the vector numbers are defined
by the BSP - is that correct?  But here, I have interrupts that are not
known to the BSP, so I think I need to use BSP-level interrupt
facilities, that are not well documented, at least not that I'm aware
of.  Am I correct in this assumption?  And if so, where do I get more
information on this level?
As you can see, the configurability of the Virtex really stresses the
BSP notion - instead of a single, static board, there are a multitude of
possibilities...
Thanks,
-Bob
